Occasional Contributor I
Clients in Bridge Mode not Populating Dashboard
Last week I migrated our London office onto our mobility controller which is based in the North of England via the corporate WAN. All AP's in London are Campus AP's in Bridge mode, everything is working fine (SSID's, 802.1x etc), however we notice that clients in London do not populate the dashboard clients section with their hostname or IP address, they do however populate the 'monitoring' section, please see below image:
We are currently using image
Can anyone advise if this is a known issue, or a more fundamental configuration error?
Many thank,
Re: Clients in Bridge Mode not Populating Dashboard
I am not sure if this is fixed in a later patch but we are now on  Could you consider upgrading to try it out?  If not, please open a support case.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
