Cluster Wireless IAP 205 Limit speed
I have a cluster with IAP 103 e IAP 205. The controller master is IAP 205. Some IAP 205, the speed are been limited. the devices are connected with AC and speed are 170 mbps . the firmware is 6.5.4.5_63641
Re: Cluster Wireless IAP 205 Limit speed
- Wireless is a shared medium. That means that devices can affect the performance of others.
- Wireless drivers can play a part in performance.  If a wireless card does not perform well at a specific rate, the AP and the client will negotiate to a lower rate to possibly improve performance.  You should then try to upgrade drivers to improve performance.
- Those devices that are at low speeds could be leaving the coverage area or dormant, and that will produce those low speeds.
- Your channels have an "E" after them, which means 80 mhz, which means it is 4 channels bonded together.  It is possible one or more channels have interference.
- You should have your device in your hand to ensure that it is not too far away and it is not in an impaired state.
Colin Joseph
Aruba Customer Engineering
Hi Colin,
the same device i use em IAP 205 com 700 mbps and other location use with ony 170mbps. the device is below IAP 205.
Check to see what band the device is connected to
Check to make sure that there is no high utilization on any of the bands.
Check to make sure there is no interference.
Check to make sure you are using broadcast filtering on all of your SSIDs.
Colin Joseph
