Combined usage for AP 105
What is the highest this should be? I have seen cases where the combined usage for an AP never reaches 10 Mbps, and others where it reaches over 20 Mbps. I am just wondering at what point is the AP becoming overloaded? Thanks.
Frequent Contributor II
Re: Combined usage for AP 105
It depends on a lot of things. RF environment, number of clients on the AP etc...
10-20 Mbps doesn't sound too much. I measured 180-190 Mbps with iperf (AP-105).
Please ,Read the following posts:
Hope all those posts - will give u the idea,I like the AP-105 very much , it's a cost effective unit - and you should get better results then what you wrote.
have a lovely evening.:smileywink:
