- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Communicate APs with controllers Loopback Interface
02-01-2018 06:19 AM
Hello!
I want to use controller Loopback Interface to communicate with APs.
Through Vlan 1 APs works well. When I use the Loopback interface as Controller ip - APs dont find controller. ADP dont work. I think it's because Loopback IP address and APs IP address are in different networks.
How to properly use the Loopback to communicate with the campus APs? Or it should only be used for remote APs?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Communicate APs with controllers Loopback Interface
02-01-2018 07:09 AM
You do not need a loopback interface. You just need to designate a single interface on the controller as the controller-ip and that is what the APs will communicate with. http://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Network_Parameters/Configuring_the__IP_Addr.htm?Highlight=controller-ip
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
