Communication between 2 MACOS device on same SSID
Hello
this is my problem
i have 2 device on mac os 1 ipad , 1 mac mini
this two device get a ip by the WIFI so it's ok, but the end user use a application on ipad  and this application dont work it use bonjour proccess
i check the the airgroup, it's enable
when i check AirGroup Blocked Service IDs
i see the ip of the device with the service
I check also Deny inter user traffic is not checked
i check also BC/MC Rate Optimization is not check
How i check is the mdns is block by the wifi controller ?
my question is can i add this service on the airgroup service already present on the controler and make work good this application ?
Thank by advance for your feed back
Perly
Re: Communication between 2 MACOS device on same SSID
The wifi controler is 3600  on 6.3.1.3 os
Please see here:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-are-the-AirGroup-service-IDs-required-to-allow-casting-via/ta-p/340268 for an example.
The blocked service id command is how you check to see if specific traffic is being blocked.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
