Hi all,
Currently I configured an IAP 103 and IAP 204 on the same network but on my virtual controler i can't see the IAP 103, I see IAP103 has not the same firmware but when i tried to change the firmware (same that IAP204) i cannot migrate firmware.
Do you know a solution for me?
Thank you in advance.
Best regards
chabin972
Chabin_972,
Here is what you do:
Obtain the same version of code for both 103 and 204 here: http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/20388/Default.aspx
Reset the 103, and upgrade the firmware manually. Do the same thing with the 204 separately. Reset the 103 and introduce it to the same subnet as the 204 and see if it joins the cluster with the 204.
