Frequent Contributor II
Concurrent Network Rogue AP issue
Hey all,
Have a weird issue. I had a lab AP cabled out into the Prod environment for some testing by user, and it's being thrashed by our Prod controller; essentially, the lab controller is on a 10.x network, and the prod controller is on a 10.y network, so the two controllers don't know each other exist, and the test lab AP (with the desired testing SSID) is getting hammered. Is there a way I can take the MAC address off the lab AP and put it into the prod controller as an allowed AP? I looked in the Control Plane settings and whitelist settings, but I couldn't find anything definitive.
Thanks!
Re: Concurrent Network Rogue AP issue
In the dashboard, you can change it to a Valid AP.
