Configuration Guide for Aruba 620
Hi All,
Can you please share the configuration guide for Aruba 620 mobility controller.
Satish.
Aruba
Re: Configuration Guide for Aruba 620
The hardware installation guide can be found on the documentation dowload site.  It is found here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=3187
The configuration of the controller is not specific to the model, but rather the version of ArubaOS you have.  Those guides too can befound on the documentation site:   http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=218
AMFX | ACCX | ACDX | ACMX
