Occasional Contributor I
Configuration Issue s2500?
I am new on configuration. My questions might be very basic. But I would really appreciate your support in learning Aruba Networks.
I am working on S2500 24 P and I am using one default VLAN and one VLAN 100.
I my self Connected to trunk port, unable to ping VLAN 100 but I can ping default VLAN.
  • Can you please tell me what could be the possible issue.
  • Also How can I enable Inter vlan routing. To ping in-between VLANs.
Attached are the ping results and configuration. I am connected to trunk port.PING RESULTS.jpgVLAN-CONFIGURATION.jpg
Re: Configuration Issue s2500?
Can you run the following commands from CLI and post the output?
show ip interface brief
show interface-config vlan 100
Tim Cappalli | Aruba Security
