Aruba
Configure AP for dhcp using console cable
What is the setenv command to set an ap to get an address via dhcp?
I have some RAPs used for surveying (with static ip) and need to reprovision them to different ap-group from a hotel.  They are currently setup with static ip, so need them to boot up and get dhcp, and then hopefully they can reach the controller.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
Aruba
Re: Configure AP for dhcp using console cable
Think I found it. Either,
setenv dhcp
or
dhcp
:smileyhappy:
you do need the set command before dhcp. It can be
set dhcp
or
setenv dhcp
