RLB
Contributor I
Configure RAP155 environmental usb settings
My customer deployed a RAP 155 to an international site with no wired internet access and has subsequently purchased a 4G card.  Is there a way to configure the USB modem using the RAP environmental settings to allow the RAP to connect back to a controller?
Randy
Re: Configure RAP155 environmental usb settings
Yes, but....You would need to have a supported 3g/4g card and carrier...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
RLB
Contributor I
Ok...the card is a Sierra Wireless 320 card which is on the 6.3.1 approved card list on arubapedia/afp.  What parameters can be set by way of the apboot parameters?  thanks...RB
What is the carrier?
RLB
Contributor I
I am fairly certain it's Telstra.
Thanks Colin...
RB
Controller-Based RAP or Before IAP version 3.4.0.4:
usb_dev = 0x0f3d68aa
usb_init  = 1,0,telstra.bigpond
usb_tty = ttyUSB2
usb_type = sierra-net
IAP version 3.4.0.4 and above:
modem-country=AUS
modem-isp=Telstra
