Frequent Contributor II
Configuring APs for HA:FF
Hi.
I am redundancy for a customer
The customer have one 3200XM and one 3400 controllers and about 40 APs
This of course means that he cannot have complete redundancy for all APs since the 3200XM only have capacity for 32APs.
This is not a problem as the customer dont need redundancy on all APs, but there are some APs that are critical and needs redundancy.
I was thinking of setting up a High Availability: Fast Failover configuration with Active/Active deployment.
Can I decide which controller will be prefered by the AP by using the LMS IP and Backup LMS IP parameters?
If this is the case, I could use this parameter to specify which APs will get redundancy and which will go down in case the 3400 dies.
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Re: Configuring APs for HA:FF
You don't need fast failover to set this up.  The most crucial access points could be in an ap-group that has an LMS-ip and a backup LMS-ip.  The others will be in an ap-group that only has an LMS-IP.
Super Contributor I
Take note using LMS and backup LMS will cause the AP to setup the GRE tunnel again to the BK LMS. I would prefer to use VRRP if the contrroller is in the same location, thus there is no need to rebuild the tunnel and clients will be least affected.
Gordon
Normal Guy
Fast Failover could also work here as well (and is now preferred over VRRP)
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Super Contributor I
Yes Fast Failover works as well and prefer but need to be on the latest AirOS. :smileyhappy:i
Normal Guy
Trusted Contributor I
but how would you enable it for only some of the APs, it seems to be a whole controller kind of deal right?
