Contributor I
Configuring RAP155 uplink with 3g USB modem
Hi guys, I have a huawei modem e5331 plugged into my RAP155, but our country and ISP is not listed inside the option.
In CLI, i can see the modem is detected but no driver is loaded. Can I know how shall I manual configure the USB modem as my uplink with desired ISP and make it online.
Valued Contributor II
Re: Configuring RAP155 uplink with 3g USB modem
I advice you to open a TAC ticket to get it done.
Venu Puduchery,
