Configuring VOIP on s2500?
Hello everyone,
Our facility just implemented a new IP phone system with Avaya IP phones.
We have Dell PoE switches for our IP phones (vlan 24) which are also used by the computer network (vlan1). All this works just fine. Now, we would like to used the already in place Aruba s2500 switches for IP phones. What are the steps needed to be done to make it all happen? These s2500 are currentlu used to power our AP105's (vlan 1). Can anyone shed some light so that my IP phones can grab an IP from my telephone DHCP server? My knowdledge of the Aruba switches is very limited.
Thanks for your help!
Re: Configuring VOIP on s2500?
I am getting 404 (page not found) when I click the link on the page you referenced...
Well, I got everything figured out!
Both Ip phone and computers are on seperate vlans and fully fonctionnal on the s2500 switches :)
Thanks for your help.
