Frequent Contributor II
Configuring radius for management authentication
We already have Radius configured on our 7220 controllers, I am configuring a new controller and trying to input the command:
aaa authentication-server radius <server_name>
But it will not accept the command. I must have forgotten some extra step, but it will only give me the option of:
aaa authentication-server internal...
Any ideas? We're running a bug-fix custom build of 6.5.3.1
Re: Configuring radius for management authentication
try "config t" before you enter that command.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
No joy:
(local-a1) (config) #aaa authentication-server ?
internal             Internal server
Radius servers can only be configured on the master controller.
Aaaah! Thank you. That explains it.
