Connecting Ap135 to Master Controller 3600
Recently, I received a replacement AP-135 for my network. I am attempting to provision it to my network and receive the same security parameters as my existing APs.
I've staticly assigned the MAC to an IP. I've also programmed the console AP to the following:
setenv ipaddr x.x.x.x
setenv netmask x.x.x.x
setenv gatewayip x.x.x.x
saveenv
boot
Would anyone have experienced this issue before or could point me in a direction?
Re: Connecting Ap135 to Master Controller 3600
What is the issue you are experiencing ?
Is the AP not able to connect to the controller?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I can't get it to boot to an IP.
It continually cycles:
" eth0: down
 eth1:down
ADP multicast: 1
ADP broadcast: 1"
repeatedly.
It looks like is not able to get an IP , can you get an IP if you plug your laptop to that same port / vlan
Thank you
Victor Fabian
Yep, I've tested this same port on APs and have received function.
This is not the same APs we have in our environment. Could this be in part to the problem?
What version of AOS are you running ?
Thank you
Victor Fabian
6.1.2.6
Trusted Contributor I
how do you do master discovery, it the VLAN attached to the controller or do you do DNS based master discovery?
i assume you don't have DHCP on that network?
