Connecting a 2nd Mobility Controller
I currently have an old Aruba 2400 mobility controller running version 5.0.3.1.  I would like to add a 2nd 2400 controller simply so that I can save money and add more access points.  I would like to use the configuration in my original 2400 and somehow have it be the master.  Can someone point me to documentation on how to do this?
Thanks!
Re: Connecting a 2nd Mobility Controller
If the current controller is a local do the following to make it a master  :
(controller) (config) #no masterip
And then it is going to ask you to reboot the controller (save the config)
After that add the new 2400 as a local on the current 2400 (master) do the following :
(controller) (config) #localip 10.10.10.2 ipsec "KEY"
And finally on the new 2400 (local) add the current 2400 (master)
(controller) (config) #masterip 10.10.10.1 ipsec "KEY"
Both have to be the same key
Thank you
Victor Fabian
Lead Mobility Architect @WEI
ARe: Connecting a 2nd Mobility Controller
Awesome!  I'll give that a shot
Thanks!
Re: ARe: Connecting a 2nd Mobility Controller
So far so good... I have the 2nd controller connected and set to read from the master.
I'm still however showing unlicensed access points above 48.  How do I fix this?
Thanks!
run  a show licenses ?
and check if you have enough AP licenses installed on your controller.
you can also do a show ap licenses
Vic
Thank you
Victor Fabian
I'm showing 47 used 1 unused licenses on the master and 48 unused on the slave.
What do you see if you run show ap license-usage ?
When you do show licenses , check if there's a flag indicating that you have to restart the controller .
flags: A - auto-generated; E - enabled; R - reboot required to activate
Thank you
Victor Fabian
On the 1st controller I'm showing...
(Aruba2400) #show ap license-usage
Total AP Licenses                       : 48
AP Licenses Used                        : 48
MUX Licenses Used                       : 0
Unused AP Licenses                      : 0
Total RAP Licenses                      : 48
RAP Licenses Used                       : 0
Total Ortronics AP Licenses             : 0
Ortronics AP Licenses Used              : 0
Total Indoor Mesh AP's Supported        : 48
Indoor Mesh AP's Active                 : 0
Total Outdoor Mesh AP's supported       : 48
Outdoor Mesh AP's Active                : 0
Total 802.11n-120abg Licenses   : 0
802.11n-120abg Licenses Used    : 0
Total 802.11n-121abg Licenses   : 0
802.11n-121abg Licenses Used    : 0
Total 802.11n-124abg Licenses   : 0
802.11n-124abg Licenses Used    : 0
Total 802.11n-125abg Licenses   : 0
802.11n-125abg Licenses Used    : 0
On the 2nd controller...
(Aruba2400-2) #show ap license-usage
Unused AP Licenses                      : 48
On the 2nd controller I'm showing this for some reason...
(Aruba2400-2) #show license
License Table
Key  Installed  Expires  Flags  Service Type
License Entries: 0
Flags: A - auto-generated; E - enabled; R - reboot required to activate
The 1st controller does not show that a re-boot is needed either.
