Connecting an AP-104 to an ANT-18
I recently purchased 2x AP-104s and 2x ANT-18s:
I found this documentation on the site for connecting an ANT-18 to an AP-92 REF: https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/How-to-connect-AP-92-to-ANT-17-or-ANT-18 – however, the AP-104s have 4x ports – which ports do I use to connect the ANT-18?
I understand that the center connection on the ANT-18 is not used - which ports on the AP-104 should the left and right ANT-18 connections be plugged into, respectively?
Ports: R1/A1 and R0/A1 or
Ports: R0/A0 and R1/A0 or
Ports: R1/A0 and R1/A1 or
Ports: R0/A0 and R0\A1
My understanding is that the:
R0/A0 and R0/A1 are the A Radios
R1/A0 and R1/A1 are the B/G Radios
Is this correct?
Any assistance would be very helpful
Re: Connecting an AP-104 to an ANT-18
On the AP-104:
R0/A0 is 5GHz
R0/A1 is 5GHz
R1/A0 is 2.4GHz
R1/A1 is 2.4GHz
When using the ANT-18, you only connect two of the connections.    I am not sure if it matters, but I would use R0/A0 and R1/A0.
Thank you for the feedback. I'll get these installed using your recommendation.
But do you need 2 ANT-18's to enable both 2.5 and 5ghz at the same time?
