Connecting an AP275
We plan to connect up a mast mounted AP-275 and was hoping for confirmation that our plan is sound.
Network - We plan to run a cat6 cable in kopex conduit down the mast connecting to a media convertor (Startech) to connect to the fibre run back to the core switches.
Power - We plan to use JW080A and have asked for an electrician to be available to connect to a "fused spur" in the base of the mast. Can anyone confirm that you can hardwire an AP in this way?
Thanks in advance for any advice!
Al
