Frequent Contributor II
Connecting partner site through RAP - need help on NAT
I am trying to work out how I can use a RAP to connect a Business Partner (BP) site to us through a RAP.  The Business partner network must appear to us as a particular subnet (10.100.x.x) so I need to be able to do the NAT on the RAP.  I also, ideally, would need a NAT pool for PC's and a static NAT for devices that have static IP's (such as printers).  The topology is below, I would appreciate any help.
Note:  The BP cannot do NAT themselves
BP LAN (172.18.100.0) >>>BPFirewall >>>  RAP >>VPN>>  Aruba Controller in our datacentre >>> Switch >>> Data servers (212.1,x,x).
