Occasional Contributor I
Connecting thin clients to wireless network
Hi
   I was wondering was is the best way to authorize a thin client to connect to a 802.1x network with clearpass. I don't want to have to log in the wireless network on the thin clients
Frequent Contributor I
Re: Connecting thin clients to wireless network
what are the capabilities of the thin client? are they able to be loaded with a machine certificate for EAP-TLS authentication?
thank you,
ACCP ACMP CWDP CWSP
They are, they are running Windows just not the full version. I also have clear pass
Antonio Barrios
Systems Engineer
ITsavvy
630-396-6300 Ext 6074
They currently have windows on them,
Would it be possible to install the network profiles on the clients?
If you could somehow push the profiles then they will be able to perform the 802.1x with installed credentials.
Pranav
