Trusted Contributor I
Connecting to Cat 6500s or Nexus 7Ks
I just want to confirm that connecting mobility switches to a core infrastructure consisting of Catalyst 6500s in VSS mode or Nexus 7K VPC, won't be a problem.  Shouldn't be a problem,right?  Will just look like an LACP link to the mobility swtiches right?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Connecting to Cat 6500s or Nexus 7Ks
We currently using 6500 in vss mode and the mobility switch connected back using static port channels .
With no issues
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Aruba
There aren't any known issues with Mobilty Access Switches in this configuration. It shoud work fine.
Thank you, both.
