Connecting to Wireless Projector
We're in the midst of setting up an Epson wireless projector. It's connected to one of our SSID's - the client machine is connected to the same SSID and it is able to find the projector using the easymp app.
The problem is: it does not display the client's machine's screen - Is there something in the VAP profile that needs to be disabled or enabled? Or perhaps something in the stateful firewall?
Thanks.
Re: Connecting to Wireless Projector
Do you have airgroup enabled ?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
yes - I don't know which service it would use though...
I see under advanced services->air group that all of the default services are disabled.
I am not sure if Airgroup will recognize epson projector.
Please try the following steps:
1. Ensure that client/projector are in a role which allows complete access to network.
2. Turn off broadcast filter knob in the VAP profile & check the behavior.
Frequent Contributor II
About: "Turn off broadcast filter knob in the VAP profile & check the behavior."  Where is it? Is the "VAP > VAP_prof > DMO check box?
I detect port 3260 over TCP and UDP (i just use nestat to check).
Could we do a new "Airgroup" service? (If yes: how to do it too please)
Best regards.
Virtual AP profile-->Drop Broadcast and Unknown Multicast
The above option should be disabled.
