Occasional Contributor I
Connecting with 5GHz then continueing with 2.4 GHz
Hello Friends,
Would you help me? How should I config the controller if I want a client to be connected to the AP with 5 GHz bandwidth when the 5 GHz antenna will be correptud, The client should continue to be connected with 2.4
Is there any solution that I can test this ???
Re: Connecting with 5GHz then continueing with 2.4 GHz
What version of AOS are you using ?
pre-6.3 you need to enable BandSteering will steers devices to connect to 5 GHz but if you are using 6.3 then ClientMatch also has the band steering functionality
Thank you
Victor Fabian
Lead Mobility Architect
