Connection but invalid IP address
Aruba(Dell) 620 controller (ArubaOS 5.0.2.1)
I finished following the Aruba setup guide and I have one of my APs associated and ready to go.  For testing purposes right now I'm just using Mac Authentication for one of the SSIDs, but some clients get ip addresses from my Server 2008 DHCP Server and others do not.
A tablet(Kindle Fire) will always get an IP address and work properly, but a windows 7 laptop always gets the 169.254.253.155 ip address and nothing I do has made this work.  I've tried reservations and static ips but it never works correctly.  I haven't done anything differently with the laptop versus the tablet.
I haven't seen any place in the gui to name the dhcp server if you are using an external one, maybe that is my problem?
Any help would be appreciated.
