Contractor management
Hi ,
Is it possible to manage contractor with third-party integration or through Airwave,where in i can track when any contractors arrive/leave job-site work area ?
Or Is it possible somehow ,CPPM can be utilized to mark contractor's attendence automaticaly while authticating through wireless or wired .
Example :Connecting to an SSID and Authnticating via 802.1x or connecting a Lan cable to the contractor vlan and CPPM and triger something which can be utilized to mark Auto attendence  .
Thanks in Advance
Re: Contractor management
I am not sure there is anything turnkey.  ClearPass has an XML-API that can be used to send a post to an external server when a device has authenticated successfully.  Please see the ClearPass exchange recipes here:  http://community.arubanetworks.com/t5/ClearPass-Exchange-Recipes/tkbc-p/clearpass-recipes
Colin Joseph
Aruba Customer Engineering
