Contributor II
Control CPU uitilization
Hi every one,
I'm using an IAP-115 with OS version 6.4.2.3-4.1.2.1_49445. I don't know how to control it's cpu uitization, just this morning with 27 users, used pre-share key, it up to 83% and no one can access the internet. But for now, with 31 users, notthing happen.
Thanks for your help,
Duc Nguyen.
Valued Contributor II
Re: Control CPU uitilization
HI,
What is the cluster size  I mean how many IAPs are there in your cluster .
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
Contributor II
I just used this IAP for my company with only one IAP for about 20 people. I setup it at the night before and it looked good until this morning, the IAP restarted 2 or 3 times with this problem and then worked fine until now.
Duc Nguyen
Trusted Contributor I
the IAP forum is probably the better place for IAP question:
http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/bd-p/IAP
you still got this issue? tried a firmware upgrade?
