Controler-7205 with IAP-207 Issue
Hi All,
Early I tried to configure IAP-207 with Controler-7205, I faced many issues some of them have been solved and still few didn't. one of the issue that you have to connect one of the IAP manually so others can connect automaticlly to the controller.
The main issue I need help with it, after connecting IAP --> "its appear on Airwave tab not on AP", and when i tried to deploy profile on it, it takes the profile but SSID dosn't show on wireless.??? any one faced that issue before.
