Controller 3200 controller and AP63 upgrade
Hi, I have 3200 controller, Aruba 200 branch controllers and Aruba AP63. I wanted to upgrade my controller into 7010, to support new features. Can Aruba AP63 work with 7010 controller or else do I need to change all access points into new models? Thanks..
Super Contributor I
Re: Controller 3200 controller and AP63 upgrade
Not sure what a 63 is, but all of the AP-6x APs are no longer supported after 6.3, so they would not be compatible with a 7010 as it runs 6.4. You would also have to eliminate the 200 controllers.
ACDX #419 | ACMP |
