Frequent Contributor I
Controller 7420 rebooted
One of out local controllers (7420) rebooted on it's own. The show boot history showed the following?
Reboot Cause: Datapath timeout (SOS Assert) (Intent:cause:register 54:86:50:2)
Any ideas on this one?
Re: Controller 7420 rebooted
This is what I found but we are running 6.5.4.0 so I guess the bug is still around..
142376
142378
Symptom: The datapath process in a controller crashed and the controller rebooted unexpectedly. The log file for the event listed the reason as Datapath timeout (SOS Assert) (Intent:cause:register 54:86:50:2). The fix ensures that the controller does not reboot due to a datapath timeout.
Scenario: This issue occurred under the following circumstances:
l WhentheARPentryforanIPaddressagedoutorforcefullydeleted
while traffic was running.
l Whenjumboprocessingwasenabledandthecontrollerreceiveda
management multi-buffer IP frame.
This issue was observed in controllers running ArubaOS 6.4.4.5.
Controller-Datapath
All platforms
ArubaOS 6.4.4.5
ArubaOS 6.5.1.0
Please open a race case, so we can capture the details of your issue.
Thanks Colin.. just opened one..
*Jon Hutchinson*
*8B Packer Ave rm 185*
*Lehigh University(610)758-5099*
All,
Has anyone know what exactly is the cause of this? and what firmware release solved this?
Thank you
