Controller Guest Provisioning ArubaOS 6.4.4.6
Hi All,
I'm having a problem is the guest provisioning page on 3600 controllers on version 6.4.4.6. I can browse to the gpp page and login but none of the existing guest account are visible and I'm unable to create, delete or edit .. essentially none of the link work. Nothing appears to happen when they're clicked.
We've also got customisation on the guest provisioning page (banner image, text and colours) all of which are being ignored.
Any ideas?
Cheers
James
Re: Controller Guest Provisioning ArubaOS 6.4.4.6
Couldn't find anything related to this in the recent release notes but it might be a good idea to consider upgrading and see if that is fix in a later more recent code since the current code is a bit old
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Victor,
As they're 3600 controller they're on the latest supported firmware. I checked the release note too. Have logged with TAC and it looks "buggy".
Cheers
James
Ahh ok cool , I thought they were running 6.4.4.6
Thank you
Victor Fabian
They are running 6.4.4.6 which is the latest rrelease for 3600 controllers,.
Cheers
James
I guess you meant the conservative release? Going to install that now.
Cheers
James
Thsi issue was fixed in 6.4.4.8 apparently. Working fine now. :)
Cheers
James
Nice!!
Thank you
Victor Fabian
