Frequent Contributor I
Controller MC 7200 Remote login
Hello Dears,
For MC 7200, I've created a Management routed VLAN, and its IP is reachable from the Core site.
I'm trying to telnet to it, but cannot.
How can I configure remote login to the Controller? For both CLI & GUI..
Thanks.
Re: Controller MC 7200 Remote login
Did you try SSH?
Tim Cappalli | Aruba Security
Not yet, will check on this.. But how can we login GUI remotely as well?
When you say remotely, what is separating the user from the controller?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Colin,
It's L3VPN in between, we can reach the Controller MGMT VLAN IP from remote NMS site, but cannot login to it.
I'm mainly seeking GUI actually..
Thanks a lot.
When you say can't login to it, do you mean there is a message?
So for late reply Colin, it's solved now, that was a firewall issue in between.
