Controller Master
Hello Aruba Team
I would like to know, if it´s possible to use the 70xx controller series in a MASTER ROLE mode?.
We´ve two units 7005.
Re: Controller Master
If you're using it as a master for the other 7005, yes.
Tim Cappalli | Aruba Security
Hello Tim
I remenber that it was not recommended to have a 7000 series controller as master of other locals
IS not that way anymore? or how is it now?
Or can you tell us what are the recommendations regarding this?
Alternetworks Corp
