Controller Redundancy
 Please suggest for below Query
1.Does Aruba 7205 Controller Support Active Active redundancy. ??
2.Do We required to interconnect both Controller with seprate link??
Re: Controller Redundancy
1. Yes. In Master / Local configuration.
2. Please explain more.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
