Frequent Contributor I
Controller Typs Redundandency
Hello, is it possible to Mix Controller Platforms in a Master-Master Redundandency, or is it necessary to use the same Model.
Thanks and Regards Mirko
Re: Controller Typs Redundandency
You can mix it up but have to keep in mind the amount of APs / Clients supported on each platform and make sure that when APs failover the redundant controller is able to support these.
What models are you using ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
3200 and 7010
I not 100% sure but I think is not recommended to use 7005/7010 as master controllers
Thank you
Victor Fabian
Frequent Contributor II
I wouldn't mix platforms with different internal architecture which will have different roadmaps for software and hardware
