Occasional Contributor I
Controller acting as Router
Hello all.
Lightning had its way with my home router last night.
Im trying to configure the controller (3200xm) in my lab to behave as the router. Im a Hulu only household and its nasty weather outside so this is pretty important(JK).
So far i am having no luck with the configuration. I have the public address and def. gateway assigned to a VLAN (999) and placed on a port. I have inter VLAN routing in place for the other VLANs and source nat enabled for 999, everything is trusted. What am i missing?
Im sure some of you experts can show me the way. What is the easiest way to accomplish this?
Many thanks for future help.
Re: Controller acting as Router
Try adding "ip nat inside" to your internal vlan interfaces.
Tim Cappalli | Aruba Security
Cappalli: I applied it to the internal VLANs with no luck on getting out. Ill try any other ideas as well.
Thanks for you time also.
Look at your show ip route
Thank you
Victor Fabian
Lead Mobility Architect @WEI
JonMwifi wrote:
Hello all.
Johnmwifi,
What device is the 3200XM replacing in your existing network?
Aruba
You mention that you have source NAT on VLAN 999 and that is your public IP.  You don't want source NAT enabled on your public interface; you want it enabled on your other internal VLANs.
My gateway is a 3200XM as well.   Relevant portions of config:
interface vlan 192
        ip address 192.168.13.254 255.255.255.0
        ip nat inside
        description "home-net"
interface vlan 470
        ip address dhcp-client
        description "xfinity-vlan"
interface gigabitethernet 1/3
        description "xfinity-uplink"
        trusted
        trusted vlan 1-4094
        ip access-group "XFINITY-LINK-ACL" session
        switchport access vlan 470
ip default-gateway import dhcp
ip access-list session XFINITY-LINK-ACL
  any any svc-dhcp  permit
  any any any  deny
AMFX | ACCX | ACDX | ACMX
Sorry for the delay in response.
Clembo you are a lifesaver. This got me going. I was trying to staticly set the public details and when i changed to dhcp on vlan 999 and fixed the source nat issue i got going.
Again I REALLY thank you.
Can't wait to get home and build out a new lab this weekend! Looking forward to a solid deployment for a change!
Thanks!!!
