Controller advice
  • 1.  Controller advice
    Posted Feb 13, 2017 05:14 PM
    I advised a customer to purchase a second IAP 205, with possible intentions of adding 2 or 3 more down the road.  They found something cheaper:  An APIN205, which needs a controller.  To make it worse, they didn't tell me they bought it for over a month, and now it's too late to return it.
    I am new to Arubanetworks, and need advice.  Will an AP205 Controller work for me?  I see it only has one LAN port.  Can a switch be attached to add more controllers llater?  Does this act as a routwer as well?  I don't really need to add that complexity if I can help it.
  • 2.  RE: Controller advice
    Posted Feb 13, 2017 05:30 PM
    An AP205 can only function with a controller.  It cannot join a cluster of Instant AP, unfortunately.  It also cannot be converted to an Instant AP.
  • 3.  RE: Controller advice
    Posted Feb 13, 2017 05:32 PM
    1. I know that.  I'm wondering if the 205 controller will allow me to add a couple more AP's in the future, and if it will work with APIN205, plus the routing issue.
  • 4.  RE: Controller advice
    Posted Feb 14, 2017 02:44 AM
    The AP205 isn't a controller. You have two options.
    1. You only use Instant Access Points (IAP). They can be joined in a cluster so you can add more than 2 access-points together with a maximum of 128 AP's in a single cluster (Aruba Instant VRD)
    2. You buy a HPE Aruba Cloud Services Controller, like the 7005. You can add regular and instant access point to a controller and manage the wireless network centrally from the controller. Depending on the number of AP's you can select your controller. The 7005 supports a maximum of 16 AP's and a 7240 supports a maximum of 2048 AP's!!
    Data sheets:
  • 5.  RE: Controller advice
    Posted Feb 14, 2017 10:36 AM
    My mistake.  I meant A200.  Shown below:
    https://www.amazon.com/Aruba-Networks-A200-Wireless-Controller/dp/B00W01FPK2/ref=sr_1_fkmr1_3?s=electronics&ie=UTF8&qid=1486768858&sr=1-3-fkmr1&keywords=aruba+ap205+controller
    I'm trying to salvage the situation without costing them a lot of money.  They are obviously cost-averse, or they would have purchased the IAP205 I suggested, instead of finding something they thought was the same, but cheaper.
  • 6.  RE: Controller advice
    Posted Feb 14, 2017 03:49 PM
    That's an ancient controller. End-of-Sale date is somewhere in 2010.
    I checked the data sheet and it looks like the controller supports a maximum of 8 access-points. But it depends (I guess) on the current number of licenses on the controller.
    I find it hard to believe that you can buy extra licenses and you should also consider support. End-of-support date is 2015!!!
    So I would advice to take the loss and buy a 7005 controller or just buy additional Instant APs and create a virtual cluster.
