Controller constantly reboots AP
I have a AP that is causing me trouble.  The controller keeps requsting a reboot of a AP when I join it to the controller to be managed as a Campus AP.  I have another Campus AP that the controller managers, and this one has no issues staying up.
I have factory reset the AP in question a couple of times, and get the same rebooting result when trying to convert to a controller managed device.
Any ideas?
Re: Controller constantly reboots AP
What version of ArubaOS is this?
AOS 8.2.1.0 running on a 7008.
MVP
The problem might be related to this message:
No available license type SECURITYGW for AP
This usually implies there are not sufficient PEFNG licenses to allow the AP to connect.
check the "show ap database" output , flags column.  I suspect this AP will show an "L" flag if it shows at all.
check available licenses on the controller.
show  license-usage  ap
A past related post:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/Why-does-the-controller-show-the-No-available-license-error-when/ta-p/179018
Shawn Adams
Aruba Networks Customer Advocacy
What is the output of:
show license debug feature-bits
PEM licensing was not installed on my controller, which was causing the issue.  Got my hands on that license, installed, and AP2 has been working fine.
