Contributor II
Controller debug limits
I get asked this question a lot, but do not know the official answer to it so I thought I post it out there as I cannot find any community links about it. So here goes...
In the controller you can run debug for various things, the common debug I have used is the user-debug. Is there any limit on the amount of debug you can run on the controller when it starts impacting performance. For example, is there a limit on the amount of user debug you can run from the controller?
Also, is there a limit on the other debugs as well ?
Re: Controller debug limits
I would run a "show cpuload" on the controller before your turn on debugging.  If at any time it stays at 80% or above, I would not turn on debugging.
After you turn on debugging, once again check to make sure it is not at 80% or above sustained.  If it is not, you are probably okay.
Contributor II
Thank you for the answer.
So what I get from your answer is the amount of debugs that could be run on a controller depends on the resources of the controller ? Is this correct ?
Correct.
