Controller doesn't seem to pass ip addresses from various vlans
I have a 2 controller system the master is a 3600 running 6.3.0.0, the local is a 7210 running 6.3.0.0.
Currently i have 3 vlans active and only one of them will pass ip addresses through the controllers to wireless clients.
VLAN 720   10.12.20.0/24  (will pass ip addresses)
VLAN 721   10.12.21.0/24  (won't pass ip addresses)
VLAN 722   10.12.22.0/24  (won't pass ip addresses)
the vlan opperational state is up on the local and master controllers, it has an ip address assigned to each vlan and i have made sure that each vlan is allowed access to the virtul ap group.
(if more than one vlan is assigned to the virtual ap group then none of the vlan's will pass ip addresses.)
If i plug a wired laptop into a port that i have assigned switch port access to it will get the proper ip address range.
The DHCP server is on vlan 10
interface GigabitEthernet2/0/2
description ARUBA LOCAL
switchport trunk encapsulation dot1q
switchport mode trunk
spanning-tree portfast trunk
interface GigabitEthernet2/0/44
description TO ARUBA MASTER CONTROLLER
interface Vlan10
ip address 10.10.0.1 255.255.0.0
ip wccp web-cache redirect in
ip pim sparse-dense-mode
interface Vlan720
description ARUBA720
ip address 10.12.20.1 255.255.255.0
ip helper-address 10.10.0.46
interface Vlan721
description ARUBA721
ip address 10.12.21.1 255.255.255.0
interface Vlan722
description ARUBA722
ip address 10.12.22.1 255.255.255.0
Any direction would be appreciated.
Josh
Re: Controller doesn't seem to pass ip addresses from various vlans
Have you tried assigning the same VLAN to one of the controller ?
Can you do a show trunk on the switch and make sure that is passing correctly ?
Also do you have spanning tree enabled on your controller , show  spanning-tree
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Also do a show trunk on the controller too
Thank you
Victor Fabian
MASTER CONTROLLER
Trunk Port Table
Port Vlans Allowed Vlans Active Native Vlan
GE1/0 10,12,520-529,701-730 10,701-730 1
LOCAL CONTROLLER
Trunk Port Table
GE0/0/0 10,720-722 10,720-722 1
spanning tree is disabled on both controllers
the 720,721,722 vlans are assigned to both controllers
Do you have any ports available on the controller to configure it as an access port with one of those VLANs ?
Thank you
Victor Fabian
i have 3 i can configure on the master and one on the local
Can you run that same command "show trunk" on your uplink switch as well
Thank you
Victor Fabian
do you know the cisco command?  show trunk doesn't work.
Also from the controller can you ping the gateway of the those VLANs ?
Try:
show int trunk
Thank you
Victor Fabian
Port        Vlans allowed and active in management domain
Gi2/0/2 1,10-12,20,30,40,50,70,80,90-93,110,120-126,130,140,150,160,170,210, 220,230,240,250,260,270,280,290,320,330,340,350,370,380,510,520,540,580,620,630, 650,720-730,920,930,940,950,960,970,980
Gi2/0/44 1,10-12,20,30,40,50,70,80,90-93,110,120-126,130,140,150,160,170,210, 220,230,240,250,260,270,280,290,320,330,340,350,370,380,510,520,540,580,620,630, 650,720-730,920,930,940,950,960,970,980
Port Vlans in spanning tree forwarding state and not pruned
