Occasional Contributor I
Controller for Dell Aruba AP93H
Dear Airheads,
I want to install a few (~10) Dell Aruba AP93H Access-Points.
Therefore I need a controller, because they don't support the instant variety ...
Which specific controller product do I need?
Is there a possibility of deploying a virtual controller as a VM?
Best regards
Re: Controller for Dell Aruba AP93H
You should not install AP93Hs, because they are end of sale.  http://www.arubanetworks.com/assets/support/EOS_AP-93H.pdf
Your options moving forward will diminish over time if you install them.  The document above details this.
Hey,
thanks for the fast reply! I am aware, that these products are EOS but anyway - I already ordered them and need to install them.
Which controller would fit?
