Hi all,
We are having a problem with the association between Clearpass Captive Portal and Aruba 7205 Controller.
We have followed a Guest Guide from one of your courses, we have created a new web-login page and the Guest Access service on Policy Manager.
Controller is added on clearpass on the Network Devices section and on the other side, Clearpass is added as Radius Server.
An guest SSID was created with the name: Invitados_ENP. During the creation wizard it was selected as Guest wlan with captive portal using credentials, on the next step we got this:
As you can see the "Enable Captive Portal" option can't be unchecked, so, we supossed that could be changed later going to Security, Authentication and then to L3. We did that, and here you can see:
After that we applied changes and when we connect to the ssid it opens the browser and redirect us to the url but the browser says that the page isn't redirecting correctly and also that: ERR_TOO_MANY_REDIRECTS
Thank you in advance!
