Contributor I
Controller management access order: internal users and RADIUS server?
Hi all,
Where can I define the order of controller management access identity source? I have setup RADIUS management access but every time I log in as a admin (internal user) it first tries to authenticate using RADIUS and only after failure it checks the internal user.
Is there a way that in management access the internal users would be checked first and only after that the RADIUS and external identity sources?
Many thanks,
Re: Controller management access order: internal users and RADIUS server?
Hi Friend,
Always strongest authentication first :)
Valued Contributor II
HI,
Are you talking about Auth servers ? if so we can change order by using up down buttons as shown in the snapshot.
Please feel free for any further clarity on this.
Cheers,
Venu Puduchery,
Contributor I
I'm not using Internal database as a authentication server. I have couple of management users statically added as you have "admin" setup in your screenshot.
I have also own user for Airwave and for other NMS to fetch data with SSH from the controllers. They'll also do the failed RADIUS attempt before using "internal" accounts :(
Unfortunately this cannot be changed. For security reasons, RADIUS/TACACS+ authentication happens first.
Tim Cappalli | Aruba Security
Contributor I
That's not good...
But thanks for the answer! Really appreciate it!
You can submit a feature request on the idea portal.
