Controller not responding
we have some strange problems with our setup:
We have a single 3400 Controller which is sometimes not responding on any webserver-port. No WEB-GUI, no Captive Portal. A few seconds (or minutes, or sometimes hours) later, anything is fine... There are no problems to access the Controller via SSH.
We checked some things:
 - There are no STP-Options enabled on the whole networks setup
 - we have a CPU-Load at about 1%
 - there are only about 10 Clients connected
 - there are no DoS-Attacks or somethings similiar to that
 - we tried different Software-Versions (6.1.3.6 at the moment)
 - we tried to access the controller via different physical ports, directly at the front of the controller - same mistake.
 - we checked all available logs for errors - nothing
So any idea? TAC?
Aruba
Re: Controller not responding
Have you confirmed there is not an IP conflict?  Can you give the controller another IP to see if it responds?
AMFX | ACCX | ACDX | ACMX
Maybe it is an issue with the httpd (apache) process? Do you see anything if you do show cpuload current? Or
show ipc statistics httpd stm ?
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
connect55 wrote:
So any idea? TAC?
Yes, TAC.
