Frequent Contributor I
Controller reboot
Our local controller rebooted on it's own yesterday (this happens occasionally_ and this is what I found on the controller:
Reboot Cause: Datapath timeout (SOS Assert) (Intent:cause:register 54:86:50:2)
Supervisor Card
There is no crash log file. We called TAC a couple of times but with no log there's not much they could do..
Re: Controller reboot
Could this be a AOS 8.x error? fixed in 8.2.0.2:
163066 Symptom: A managed device rebooted unexpectedly.
The log files for the event listed the reason as Datapath timeout (SOS Assert) (Intent:cause:register 54:86:50:60).
The fix ensures that the
managed device works as expected.
Scenario: This issue was observed in managed devices running
ArubaOS 8.0.0.0 or later versions.
Resolved in 8.2.0.2
more here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28753 - page 12
Thanks for the update.. We are running 6.5.4.0 at the moment.. planning on
upgrading this summer after the classes have ended
*Jon Hutchinson*
*8B Packer Ave rm 185*
*Lehigh University(610)758-5099*
magnumpi83, the best thing you can do is to put a console cable on the controller and have a PC that captures the output there constantly.  It is entirely possible that there is crash information on the console that would help TAC get to the bottom of it.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
