Occasional Contributor I
Controller timezone
We have an Aruba 3400 Controller, we used it a month ago in China with IAP-135's converted to work with the controller.
Since then we have cleared the config and set it up for an event in SF with the correct timezone etc. yet when the wifi clients hop on the wireless, the NTP shows that they are in China when automatically setting time zone or going to maps.
Our version of code is 6.1.3.6-Airgroup
Input much appreciated.
Re: Controller timezone
Well, before you even attempt fixing the timezone issue, you are in violation of the regulatory domain laws as this controller is set to China and is now terminating APs in San Francisco.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Super Contributor I
With controllers the controllers are specific to the country code and the APs are universal. With IAPs running instant they're specific to a country as well.
ACDX #419 | ACMP |
It's a US controller with US AP's deploying wifi at an event in China for a US company....why is that in violation of regulartory domain laws?
Super Contributor I
In the US it would not be if it's a US controller, however in China (even if it's a US company) you would be subject to China's communications laws, so to operate in China you would need a controller that is built for that country code.
ACDX #419 | ACMP |
Super Contributor I
Did you reset this controller? (write erase all)
If not, check if your regulatory domain profile for your AP-group is configured correctly. (AP-Group -> AP -> Regulatory domain)
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
