Contributor I
Controller upgradation from 6.2.1.3 to 6.4.2.9/
Dear All,
I want to upgrade my 7210 controller which is in Master and having 1 vrrp redundancy neighbour. how can i acheive this and what all the prerequisites..?
We have ap 135 registered to the controller. Whether these ap's will join after upgrade.
Thanks  in advance
Re: Controller upgradation from 6.2.1.3 to 6.4.2.9/
You should be fine.  Please read the 6.4.2.9 release notes thoroughly to see if anything specific in your environment would keep you from doing this upgrade.  The latest GA release is curently 6.4.2.12.
