Frequent Contributor II
Controller upgrade 3.3.x to 5.0.4.x and rap authentication issue
if someone have issue after upgrade controller from 3 to 5 i've fix a very strange issue:
on rel 3.x i see the config file and i see
user rap
password rap
so i create the same user on rel 5.x because in the upgrade this data is lost
but my rap cannot connect,
so log says "User RAP Failed Authentication"
after some experiment :smileymad: i foun the issue......
user was RAP and password RAP
so it seems version 3 show you in config info rap user and password in not case sensitive ways
creating new user all in uppercase my issue stop.
Andrea Consadori
ACMP 5.0 and 6.3
