Frequent Contributor I
Controller upgrade
We have a master-local controller environement and we want to upgrade the AOS on the controllers to 6.1.3.6-AirGroup to have support for the AirGroup. The current version we are running is 6.1.2.4_30768. We have 3 controllers M3 and one 3200, more than 800 AP-105 and few RAP-2WG on production.
Any advice?
Thanks.
Re: Controller upgrade
Here's a good guide :
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-How-to-Upgrade/m-p/5336/highlight/true#M228
Make sure you removed the LMS backup when you are about to upgrade this way APs won't flip/flop between controllers and added back once the upgrade has been completed.
Also read carefully the release notes.
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Instead of that AirGroup train for the controllers, have you considered 6.3.0.1?  That includes AirGroup and other new features like centralized licensing, ClientMatch, and AC AP support.
Is the 3200 the "3200XM" with the extra memory?  If not you cannot upgrade to 6.2 or later
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Thanks for the quick reply.
