I see that it is not possibile to convert an IAP93 to AP93 on a OAW Controller, because the maximum firmware version for OAW controller is the 5.X series, and this functionality is not supported.
So, my question is: Can I convert the IAP93 on an Aruba Controller with AOS 6.X and after change the parameters of the converted AP to associate it on the OAW Controller?
Massimo
